Zum Hauptinhalt wechseln
Model CUH-ZCT1. Dieser Sechsachsen-Controller mit dem 3,7 V Lithium Akku, den Sony im November 2013 auf den Markt brachte, ist leicht zu reparieren. (BEACHTE: Die Teardown-Anleitung ist NICHT für dieses Modell)
387 Fragen Alle anzeigen
My left analog stick moves down alone? what should I do?
my left analog stick moves down alone? what should I do?
control already open but not found the problem
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 46
8 Kommentare
I cant believe this actually works dude wtf lmao
von
Wow!! I feel dumb!
Thank you for this. Really wasnt keen on buying a new controller.
von
This worked. Thank You
von
Lmao, thank you so much, it took like 20 seconds.
von
well, after looking everywhere, i came across this. didnt think thered be any way THIS is what would fix it. it did though. perfectly. hope more people see this.
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
9 Antworten
Gewählte Lösung
I found this topic after having my controller keep slowly moving upwards all the time, but thought the idea of just buying a new controller, a bit too excessive.
So I played around with various other options and finally fixed it by moving the stick in different positions and blowing as hard as I could around the ball at the base of the controller stick, to remove any dust etc which may of got inside.
It works perfectly now.
You can use the ps4 web browser to know when it's fixed, by moving the cursor in different directions and then see if it carry's on moving by itself or not
Update: I also found it useful to get a thin piece of card (about 5mm's wide) and slide it down between then start to rotate the controller stick, as this removes other gunk that blowing wont always get rid off.
War diese Antwort hilfreich?
Bewertung 87
74 Kommentare:
My right analog stick would move up on its own at random and I tried everything from resetting it, to opening it up to clean all of the contacts and prop up the little squishy bit that presses the plastic circuit to make contact with the circuit board. I spent about three hours trying things, putting the controller back together, trying it out, and starting over. I just found this comment and tried it out, and now it works perfectly
von
It work's for me,THANKS!
von
This is stupidly awesome it works lmfao
von
Bro you are awesome. It works perfectly, THANKS!!!
von
Working here too...many thanks for this :).
Still, this is so stupid...
von
69 weitere Kommentare anzeigen
Water use isnt advised as it can cause damage to electronics inside, making the issue worse. If you want to try an alternative to a repair service, try spraying compressed air onto the balls of both analogues, this will clean it out and hopefully sort your issue, never use your own breath as it can leave moisture inside, having the same effect as putting water onto it
Bewertung 4
3 Kommentare:
Is there a potential for it to fix itself if you do use your breath? Maybe it can be dried with compressed air?
von
Try soaking it in soap then put it in the microwave
von
Soap and microwave worked for me
von
Try this my dude.
https://youtu.be/_LePBsn3vkA
Bewertung 3
3 Kommentare:
This worked for me when none of the other solutions listed did (not that they didn't fix the other folks relevant problems), thanks!
von
that is a grabify link dont click it
von
Finally!!! This is it guys! Thank you so much dude. I bought a brand new controller and had this issue on my r3. So close to perfect yet so far, until now. Thanks again
von
Marcelo Marques, that is the sign of a wore out analog controller. You will have to replace it. The controller is available at places like this This will require to unsolder the old one and then resolder the new controller. Hope this helps, good luck.
Bewertung 1
4 Kommentare:
I remember on the ps3 controllers all you had to do was clean certain contacts inside the controller, is this not possible with dualshock 4? Is replacing the analog stick the only option?
von
Mine is new and it does it too.
von
Had the same problem replaced the stick and it's still there, might be a chipset or board problem??
von
Mine still won't work try what y'all said and still moves on its own
von
I had the same problem but I guess i had to trick my way through it...lol! When it shifts to the unwanted position calibrate it and make sure no button is pressed during calibration...this is more like making a new setting over the default. Thank me later... cheers
Bewertung 1
2 Kommentare:
Yes but mine, i will flick it to the left and my character on the game fortnite and call of duty, will swing to the right, and i dont know what to do
von
Try turning your controller round the other way. :)
von
I had the same problem. I opened up my controller and removes the thumb stick. I opened up the green box on the left of the analog stick on the there was some black residue on the contact. I cleaned it out with rubbing alcohol and it works fine now.
Bewertung 1
1 Kommentar:
Hey i have a little question. How many percent rubbling alcohol did you used actually becaue i have the same problem i really need to know how i will do it myself .
von
If you want honesty, I was reading this thread while I fixed it, I hammer punched it fairly lightly, it worked, but I could lock the analog stick to the left, I put some water on the left side of the left analog stick's ball, now it works fine!
Bewertung 0
Using electronic spray cleaner will work. Thanks for asking, Matt of Martins TV Repair!
Bewertung 0
I'm not sure why these joystick modules dont have dielectric grease inside their housings. It would keep contact on the inside making external particles less of an issue. I opened mine up, blew it out, and put a tiny dab of silicone grease in them. Another fix would be prevention. Wash your hands before use, and stop eating and playing games at the same time! All that worthless crap you put in your bodies as snacks are really screwing up your equipment. Also , try turning down movement sensitivity to compensate until you can't, then buy a new one. Playstation is better than all those other aftermarket hardware makers.
Bewertung 0
2 Kommentare:
Mine DS4 is brand new and is moving on it's own so it's not about eating and playing
von
easy answer. manufacturers want you to buy a new one, not fix the one you already paid for:) cheers.
von
Antwort hinzufügen
Marcelo Marques wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 26
Letzte 7 Tage: 182
Letzte 30 Tage: 787
Insgesamt: 473,331
