Zum Hauptinhalt wechseln
Die zweite iPad-Generation mit WiFi, GSM und CDMA Modellen. Einige Modelle wurden noch einmal aufgepimpt vor dem iPad 3. Die Reparatur ist schwierig und verlangt Hitzezufuhr und Hebeln.
730 Fragen Alle anzeigen
Frage geschlossen
started dissambling ipad 2, now worried
its the wifi-3g model
im still in the process of trying to remove the screen
http://s17.postimg.org/3kfrk01db/IMG_002...
when this happened !
http://s29.postimg.org/5zhf7pi7b/IMG_003...
looks like a peice of metal sticking out... scared me
what is it? have i ruined it... do i just push it back in?
i thought the atenna is more near the home button
anyway wifi still works, home button still works so everything seems ok at the moment, tempted to call it a day and take it to the shop... still need to know what it is tho
Update
seems i was worried about nothing, it was little bit of metal poking out from me scraping the case with the pry tool
http://s12.postimg.org/5y0evmhfh/IMG_003...
i think if i tear this plasticy thing all around the edge then the job will go along alot quicker, got to be careful tho because i think i pushed alot of it into the ipad during the start
forgot to mention im sick of watching youtube videos.. gets me nowhere lol but thanks
Update 2
i understand now, i guess the damage is already done to the bezel so i may aswell continue with my unorthodox method.
ill have to order a new one, i dont consider them cheap myself
i thought i was doing it wrong at the start but it was literaly the only way i saw possible, o well
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hi there it seems you have pryed between the metal frame and plastic bezal you need to pry between the glass and plastic.
The iPad screen is a trick enuf repair go look at some videos and reevaluate when your doing..
War diese Antwort hilfreich?
Bewertung 0
You are scraping the metal case off. Pry between the glass and the plastic bezel. In fact it is okay to even destroy the bezel and put the new one on since it is so cheap.
Bewertung 0
Just be careful with the wifi and power button antennas and flex cables very very easy broken.. Just a heads up the videos will show you the locations
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 88
