Zum Hauptinhalt wechseln
Modell A1312 / Mitte 2011 / 2,7 & 3,1 GHz Core i5 oder 3,4 GHz Core i7 Prozessor, ID iMac12,2
708 Fragen Alle anzeigen
Replace 1 TB Internal 3.5 Hard Drive with Dual SSD
I am wanting to replace the 1 TB spinning hard drive with two SSDs. I understand and have researched on adding a SSD and keeping the spinning drive but I am wanting to replace it with 2 SSD. A typical 3.5 hard drive should be more than the thick enough to cover the thickness of two Samsung 840 EVO drives that I am considering. Does a kit already exist that allows for this? I know Samsung makes a desktop kit that allows 1 SSD to be mounted in a 3.5 inch bay but that is only 1 SSD.
Also I have read some on special firmware on the Apple drive for temperature sensing, is that still accurate? Would I just be better off leaving the OEM drive intact?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You might want to go here and take a look at Other World Computings solution called Data Doubler. As far as I know, its a kit that will allow you to add a SSD to your existing drive. If you were wanting to yank out the existing drive and substitute another SSD drive, I dont see a problem. But, OWC has tech folks on staff and give them a call or chat with a tech person and run that by them.
http://eshop.macsales.com/shop/drive_bra...
Hope this helps
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Matt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 221
