Zum Hauptinhalt wechseln
Frage geschlossen
Power adapter turn on issues
Hi,
I have a Macbook Pro model A1211. It won't start with the adapter but runs from battery. I bought a new 85W adapter but still won't start. Is there a way to determine for sure if it is the "left logic board"? The light of the Mag Safe adapter shows green even when battery is not present. I have reset the SMC and PRAM.
Thanks in advance,
Mike
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Download and run Coconut battery to see if you are getting power from the left I/O board to your battery. This machine usually requires at least a20% charge on the battery (that's 20% of the original capacity). The left I/O board is Apple Part # 922-7187.
You may need version 2.6.6 instead of version 3.
http://www.coconut-flavour.com/coconutba...
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 96
