Repair with Power On?
iPod power button is shot and won't power off. Should I go ahead and try to replace the screen with the power on or pass on the repair?
Ist dies eine gute Frage?
You have a couple options here:
1. Run the battery dead by leaving it on or waiting a few weeks as it sits on standby.
2. Taking the chance and repair now while on standby. Best case scenario it that there are no adverse effects. One scenario is that you may get the white screen and need to reset the iPod. Worst case scenario is that the back light filter or something else may get damaged during the repair
I would recommend option 1 and replacing the volume power cable while you have it apart.
War diese Antwort hilfreich?
Are the LCD and touch screen still working? If yes, then you could be in luck.
If the iPod touch you have comes with the "Assistive Touch" option under Settings>General>Accessibility>Assistive Touch, try this:
Turn " Assistive Touch" on. The white/floating "Home Button" will appear on the screen. Click on it. Then click on "Device." Then click on "Lock Screen" continuously until the "slide to power off" bar appears. Voilà..
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 72
1 Kommentar
It's an iPod Touch 4th Gen
von Jason Younger
