Zum Hauptinhalt wechseln
Released: October 2001, Model: IBM Thinkpad A30
2 Fragen Alle anzeigen
Is it possible to install a wireless LAN mini PCI combo card?
How can I install a wireless mini PCI combo card on IBM Thinkpad A30? I can not find the "MAIN" and the "AUX" cables under the mini PCI expansion slot door. Is there anyone who can help me? Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
romey, best to do is to disassemble the laptop and make sure that it has the antenna assembly installed. That is where those wire come from. Use these guides to work on your laptop. The part number for the assembly (reference marker 4) is 27L0684
Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
Here is the service manual for your laptop:
http://tim.id.au/laptops/lenovo/thinkpad...
You can plug in a Type II or Type III PC Card in this laptop. (P. 46 in the manual)
Here is a really good PC Card which will provide wifi for your laptop:
https://www.amazon.com/NETGEAR-RangeMax-...
It has Wireless-N and WPA2. It will definitely work with Vista, and probably with Windows 7. Here is the information about this card:
http://www.downloads.netgear.com/files/G...
Bewertung 0
Antwort hinzufügen
romey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 257
