Zum Hauptinhalt wechseln
Reparaturinformationen und Anleitungen für das Apple iPhone 5c, das am 10. September 2013 angekündigt wurde. Modell: A1532, A1456
How can I fix a keyboard problem?
iPhone 5C keyboard will not type certain letters after screen repair. Everything else works fine except for the keyboard. It wont allow me to use the numbers button. Tried a hard reset. Did not work. What can i do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 13
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive.
But really must try a new known good screen first, as this is still the first suspect.
War diese Antwort hilfreich?
Bewertung 4
Hilfreichste Antwort
Sounds like a faulty digitizer to me, or a poorly seated digitizer connector. Did you do the screen repair yourself, or did you have a repair shop do it?
Bewertung 4
4 Kommentare:
My sreen is smashed but this was happening before i
Smashed it
von Teilen
no it was not
von Teilen
I had the repair shop to do it.
von Teilen
You should tell your shop about it. If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive. But really must try a new known good screen first.
von Teilen
Usually, the problem occurs after a screen has been replaced and the digitizer cable has not been seated properly. You have to ensure the correct sized screws fitted into the correct position. There are four screws holding down the shield that covers the display cables and if you mix them up then your shield and cover will not fit correctly and the cable connectors will move and cause digitizer and screen faults. Uisung #000 screwdriver you can easily remove and refit these screws, if you are unsure the bottom two are the smallest (1.3 mm screws) and then the upper left is slightly larger (1.7 mm screw) and the far right screw is the largest of them all (3.25 mm screw). You can prior to the removal use a coloured marker or pen and colour code the screws to the position they belong to, remember the two lowest screws (1.3 mm screws) are the same size so can be coloured the same. This should help resolve any problems with exchanged screens and cabling to screen faults. Thanks guys
Bewertung 2
hello,
this is in relation with touchscreen ic chip when everything is all right...
Bewertung 1
My keyboard is frozen also screen
Bewertung 1
my iPhone 5s I got the screen repaired and the u and n dose not work on the keybord
Bewertung 0
Antwort hinzufügen
keldavis5 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 35
Insgesamt: 31,856
