Zum Hauptinhalt wechseln
Dell 19" LCD Monitor, charcoal gray in color, released in 2004.
8 Fragen Alle anzeigen
Display darked out in 1 second
My Dell has very similar board layout as this one. It display for about 1 second after each power on and then darked out. Power off and on again give me another second but that's is. I shine a strong light on the screen in the hope that I can see a shadow of the display but nothing. With help from this site, I tear down the case but not able to troubleshoot because of my limited knowledge.
With the power supply board alone (not connect to any other board), tested it and all +5V and +12V output are ok and very stable. Found a pin labled "on/off along the DC out to the controller board (i.e. the one with the VGA port). But no matter I connect ground or +5V to it, the inverter still has nothing out.
Can anybody give me an idea how I can troubleshoot the problem? Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
senderj, sounds like a bad inverter. You can try to recap the PSU or replace it.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
senderj wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 517
