Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
No vibrate and ringtone after screen replacement
Hey guys,
a few days ago I repaired an iphone 5s for a friend of mine. After the repair it doesn't vibrate and ring but sounds like music spotify and youtube work.
The ringtone switch is not on vibrate and the "don't disturb" option is also not switched on.
I have absolutely no idea what it could be, since I only worked on the screen itself and not in the housing of the iphone.
Regards, Frederick
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Know this is an old post but I was having the same problem after buying a replacement screen on Ebay. Turns out the front camera cover was touching the vibrate motor preventing it from turning. I fixed this by pressing the metal hook that is on the right side of the camera cover in a little bit with a screwdriver and now it's working. I also had previously tried repositioning the camera and camera holder but this didn't solve it. Let me know if this helps anyone.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
This is the correct answer 100% Took me 2 weeks to figure it out a couple years back..
von
Yes I can answer this as well. It was exactly that. The front camera steel cover was contacting the vibration motor. Thanks for the tip!!!
von
The same thing happened to me several times.. I'm going to try replacing the vibrate motor, but I'd like to know how to prevent it from happening again.
Bewertung 0
Antwort hinzufügen
Frederick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 3,794
