Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1203 Fragen Alle anzeigen
What's the best replacement hard drive to install in my MacBook?
I have the mid-2008 Penryn MacBook with the factory hard drive, and I want to replace it with a new one. I am a graduate student and mostly use this computer for school.
I am interested in trying a 1 TB SSD Hybrid, which is listed as compatible on iFixit, but have seen some places that this model can only handle up to 750 GB. Does this mean I need to go with a 500 GB hybrid instead? Is this a good option or are there other recommendations?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
This question was migrated from http://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi Cara,
The issue is the physical size of the drive you are installing. As long as you have the correctly sized drive (physically) and the drive is able to interface correctly with the systems SATA I (1.5Gb/s) interface the OS (OS X 10.7.x Lion being the newest you can use) can support a larger drive. Here's a good Apple TN on the OS's limit: Mac OS X: Mac OS Extended format (HFS Plus) volume and file limits. I doubt you'll hit these limits ;-}
As to the drive you do have an issue here as your system has the very first HD SATA spec (SATA I). So you will need to be careful on what drive you get. Make sure it is able to run at the SATA I (1.5 Gb/s) I/O speed. Seagate makes a SSHD hybrid drive that should be just fine here Seagate Laptop SSHD Drives.
But before you do anything make sure your system is running the latest firmware. Follow this Apple TN on how to check it and update it if needed: EFI & SMC firmware updates for Intel-based Macs. Lastly, you may want to get a FireWire (400) case to house your current 2.5" HD so you can transfer your files and have a backup drive (just in case).
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Cara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 157
