Zum Hauptinhalt wechseln
Kam im Juni 2012 auf den Markt / Intel Quad-Core i7 Prozessor mit Turbo Boost / bis zu 1GB DDR 5 Video RAM
597 Fragen Alle anzeigen
Serial No. went missing on my MacBook Pro
Hey guys!
Have you ever met this?
I have been recently suffering from nVidia issues on my mid2012 i7 15" MBP. It freezes all the time, have little squares, and lines on screen, when frozen. It wouldn't be a problem, because I have Apple Care, BUT!
As far as I am experiencing these issues, my motherboard forgot it's serial no. It's like if I had already changed my logic board, it says "System Serial#".
I am working with Macs, I am repairing them since 2010, but I've never seen anything like this, and this machine's logic board hasn't been changed, that's for sure, bcz it's my own.
I attach some pictures, where you can see, that hardware monitor app recognizes that I have "switched" computer, but remembers an older machine (with my serial no.), which is quite similar.....
https://www.dropbox.com/sh/0xrdv6o3f700q...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Would you mind giving us full serial number off the bottom of the machine.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Did you check the systems firmware? Here's Apples TN on how to check and update: EFI & SMC firmware updates for Intel-based Macs
What happens when you boot the system off of an external HD or thumb drive which you know works correctly on a different like system? Does it still mess up?
War diese Antwort hilfreich?
Bewertung 1
Will this solution work on a Mid 2013 MacBook Air 11”?
Bewertung 0
1 Kommentar:
Time marches on!
This solution was workable with the older OS-X OS's. I'm sure you are now using a much newer version of OS (MacOS) I would recommend you give us all of your systems details in a fresh question here: Ask a Question
von
Antwort hinzufügen
Andras wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 11,261
