Zum Hauptinhalt wechseln
The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
30 Fragen Alle anzeigen
Need a source for replacement battery.
I have searched for a replacement battery for the Nook HD to no avail. All that can be found are not for the HD. None have the 4000MHA, 14.8 Wh rating.
Does any one know of a source, other than B&N (who won't sell the battery) ?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
jmbiii3, the battery number for your Nook HD is BNA-B0002. the battery appears to be available right here and here as well. Of course, always check with the vendor. If you are truly fixed on the 4000mAh you can check on here
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks ! The battery in the HD is a 4000mAh and I would like to keep it at that rating. I'd order the one you mentioned last, but can't quite read the order info. LOL
von
Here you go!
https://www.newpower99.com/SearchResults...
Bewertung 0
Antwort hinzufügen
jmbiii3 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 2,354
