Zum Hauptinhalt wechseln
Repair guides for various Nikon camera accessories.
21 Fragen Alle anzeigen
Remove a stripped lens mount screw from Nikon 300mm f/4.5 AI-s lens?
I'm trying to remove the lens mount, so that I can disassemble and clean a vintage 300mm lens (something is on the interior elements--possibly oil from an ill advised attempt to lubricate a sticky focus mechanism) . Problem is, the screws holding the lens mount on are JIS, not phillips, and one of them is now stripped--the stripped screw is size 00. The other screws are can be screwed out quite easily with JIS screwdrivers. Tried the rubber band trick.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try heating it up a bit (heavy duty soldering iron), the loctite used on the screws will soften a bit which might allow you to get it out.
Otherwise its time for a drill to pop the head off. Then you should be able to grasp the shank of the screw with a pin vise or carefully slot the top for a straight blade.
Mind the metal flakes as you don't want them to get in to the diaphragm control mechanism.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
jerwin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,321
