Zum Hauptinhalt wechseln
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
35 Fragen Alle anzeigen
Can water spillage be fixed?
My wife spilled water on our new HP 2000-2d22DX. I let it dry out for 2 days and it turns on but the screen is black and then like 10 seconds later it turns itself off. Can this be fixed or is it a lost cause?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It could possibly be repaired... but it is a lot of work. You may have only blown a fuse... you may have blown the logic board. Without skilled examination no one can say for certain.
Follow the tags at right for a glimpse of what you're in for.
You could take it to a computer repair shop for an estimate of what's wrong, and what it will cost to repair. Depending on what the technicians say is damaged you may be able to DIY.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Will give it a try. Thanks for the suggestions.
von
Do you know where I can find a repair manual for the HP2000. I don't know where the fuse or the logic board are? Thanks again for the suggestions.
von
Sorry no source for a manual... try Google. Jamie - For future reference you posted a Comment in the place where only Answers belong. Please use the add comment link to the appropriate Answer, or, update your Original Question.
von
Antwort hinzufügen
Jamie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 112
