Zum Hauptinhalt wechseln
Lenovo ThinkPad T400 was a laptop introduced by IBM for corporate and commercial use. The T400 was released along with the T500 in July of 2008. Similar models include the 400, 410, 420, 510, and other models in the ThinkPad T series.
Are 16GB RAM (2x8Gb) possible on my Lenovo T400?
Have anyone tested 2x8GB RAM on a Lenovo Notebook Thinkpad T400? If yes, does it work? Any problems? Type of RAM Modules?
Thanks a lot!
Maritn
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Here's what the Lenovo support doc states: Detailed specifications - ThinkPad R400, T400.
From what I can find this system is limited to 8 GB total RAM (2 x 4 GB modules). I don't see any references on anyone trying to push this system beyond that.
Remember your OS is also a factor here, you'll need a copy of a 64bit version of Windows before even trying more than 3 GB.
As long as you can return the memory you could give it a try. If you do, first try one 8 GB module first then try two. Please let us know what you discover.
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
Windows 7 Ultimate
X86
4 GB
X64
192 GB
Windows 7 Enterprise
X86
4 GB
X64
192 GB
Windows 7 Professional
X86
4 GB
X64
192 GB
Windows 7 Home Premium
X86
4 GB
X64
16 GB
Windows 7 Home Basic
X86
4 GB
X64
8 GB
Windows 7 Starter
X86
2 GB
You did not tell us which OS you have. So that limitation will depend on your OS.
von
Thanks OT! I forgot the Starter version only goes to 2 GB
von
I was able to upgrade my laptop to 16 GB.
2 pitfalls:
1. Corsair RAM does not play well despite Corsair's claims. Stick to either an OEM supplier or Crucial.
2. Both sticks of RAM must be the same size. Otherwise, you may see strange things on your screen. This is a known bug with the Intel chipset in this laptop.
Bewertung 3
2 Kommentare:
I can't seem to edit my own answer. I should've written "laptop to 8 GB" and not "16 GB".
von
Can you list exact model of RAM chips which you verified with the T400?
von
I own a Lenovo T420 and have been running 16Gb (2x8Gb)for years now. When I initially did this 3 years ago, I did make sure I was using the latest BIOS at the time, and after putting the 2 8Gb Crucial SoDIMMS in it was recognized by the BIOS at first boot. After saving the bios, F10, I rebooted into W7 x64 Professional with no issues as well...with it recognizing all 16Gb of it. I upgraded to Windows 10 x64 Pro since then and again no issues. On both W7 and W10, I disabled Virtual Memory altogether by opting for "No Page file" and have had no issues in doing that either. Hope this helps someone.
Bewertung 3
1 Kommentar:
would please share with us the ram link please. I am planning to do 16 Gb but it don't knows the compatiable ones.
thanks
von
Antwort hinzufügen
Martin Gschwendtner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 14,807
