Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Logic Board parts missed beside the power connector.
I have changed the power button cable to my Iphone5, then it keeps in restarting every 3~5 minutes, when I check the logic board I found it missed 3 part "resistors or capacitors"? I am not sure.
attached photo for that area, and I need your help to identify which parts those are, and from where to buy?
Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I had a similar self-inflicted issue caused by my gorilla hands trying to remove a stubborn battery and getting impatient. Prying on the battery in the area of the battery connector whacked the FL11 battery management inductor. The phone reboots every 2 - 3 minutes because the battery is no longer being detected. The battery diagnostic information indicates no voltage or current, and 0 charge cycles - I'd say that's a pretty good clue for FL11 pry damage. Now to see if I can get it fixed...
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
From left to right:
C9, C279, FL11
C9 is just a ripple filter, you won't die without it.
C279 is a filter for battery management I/O
FL 11 is an inductor for battery management I/O. Without it the system cannot read battery status so it keeps powering off as a safety measure.
War diese Antwort hilfreich?
Bewertung 10
3 Kommentare:
Hi there! Can I replace that C279 capacitor with for example C67 100PF 16V 5% capacitor? What is that (PF)? Thanks
von
PF = picofareds
von
But is the FL11 present in like the ipad pro? because it keeps powering off and i cannot read battery status?
thankss in advance
von
Ramadan, this is strictly to augment Tom Chai's answer. He is absolutely correct and I do just want to complete the answer to your question.
Reference designator C9 is a 56PF 16V 5% capacitor in a 01005 package
Reference designator C279 is a 56PF 16V 5% capacitor in a 01005 package
Reference designator FL11 is a 120OHM-210MA filter (TDK MMZ0402S121C)
All parts should be available at places like Mouser.com or Digikey.com as well as many others.
Bewertung 8
15 Kommentare:
I found it is too expensive to order that items from Mouser.com to Egypt, so! do I have any other chance to fix that loop of restart with less cost$?
von
Mouser and Digikey are just the stores I use in the US. I am certain there are suppliers that are closer to you. Just out of curiosity, how much were they going to charge you?
von
for the ( C9 + C279 )
MERCHANDISE TOTAL:
$0.57
SHIPPING CHARGE:
$75.00
ORDER TOTAL:
$75.57
But: the FL11 they said (Minimum Order 16000
), so it seems it is impossible for me to import them....
* If any one can help me with that ... it would be highly appreciated.
von
Another concern,
here in Egypt I meet some technicians said to me they know how it fix this reboot issue without replacing those items! is that right ??? as I feel that is wrong to do, I think all I need is: to replace that parts only.
von
FL11 would give you trouble. It is needed to monitor the battery. Contact me by email, I could probably send the parts to you for way less. FL11 is available at digikey.com for $0.26
von
10 weitere Kommentare anzeigen
is F11 a part that needs to be soldered on?
Bewertung 0
iphone 4 2 motherboard 2 pad conector on the p.c. board was fall where the conector of battrey and 2 capacitores c9 c279 how can i soldering the connector of battrey when 2 pad from p.c. fall?
or if i send you from isreal the 2 motherboard how much its cost to fix it?to send to isreal or show me i can fix 2 pad that fall?where i can buy 2 cap.
c9 c279 mor cheap?
thank you
Bewertung 0
use a schematic. locate the missing filter on the schematic, then search a dead board for same filter
Bewertung 0
Antwort hinzufügen
Ramadan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 16,190
