Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
home, lock button failure, gsm module failure after screen replacement
hi!
i replaced the screen of my iphone 5 and did it really gently, so i didn't damage anything inside. But after the replacement the home, lock buttons stopped working and also there was no gsm signal. telephone is constantly in recovery mode, but it is possible to bring it from this mode using tinyumbrella, for example. i brought my phone to the best repairment center in town and after 2 days of inspection they said that they couldn't help. they didn't find any damage inside, they tried to change all buttons new screen but it didn't work either. telephone doesn't work also with old cracked screen, but it worked before i changed it. So i would be glad if someone help me, or give me a contact of a person who knows how to fox the phone :)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Pry damage to the motherboard from prying battery..
Look under the long black interconnect cables just opposite sim tray there will he missing components
War diese Antwort hilfreich?
Bewertung 0
Hi Sergei,
This is classic pry damage from prying the battery on the logic board side, I see it every day.
I fix mail in iPhone 5 pry damage constantly, including International phones. We can restore your home and power button function, guaranteed.
I'm worried about your searching no signal problem though. Look very closely at the glass chip located on the edge of the board just under the SIM tray---if there is a slight crack or chip on this chip caused by a slipped screwdriver on the nearby screw hole, then this could be the source of your searching no signal--I've seen that twice.
First, however, rule out common causes of searching no signal like date/time problem.
I will post a link to my pry damage repair service so that you can inspect your phone to see if it matches the damage in the pictures.
http://www.mommyfixit.com/iPhone_5_Pry_D...
Bewertung 0
What in God's name is a GSM module?
Bewertung 0
Antwort hinzufügen
Sergei wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 272
