Zum Hauptinhalt wechseln
1,83 GHz Core Duo oder 1,83, 2 oder 2,16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Fragen Alle anzeigen
After turning the iMac on, all I see is blue.
After the power went off one night I tried restarting the computer the next day and it went smoothly past the first part where you see the apple but right afterwards it came to a blue screen and that's how it stays.
I've tried turning it off and turning it back on but that didn't work. I also tried leaving it for a few hours but all it did was flicker to a light blue then a faded blue.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds like it corrupted the system software. Try holding down the Shift key on start up. Next startup from your original system installation disk, hold the C key down. Run Disk Utilities on the hard drive and repair it then give it a try and let us know your results.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
It worked!
Thank you so so so much!!
von
If you accept this answer it can be used to help others.
von
Antwort hinzufügen
Jasmine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 74
