Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1158 Fragen Alle anzeigen
Why does my iPhone3G only works with external MIC/Headset?
My iPhone 3G only works with external mic/headset.
People cannot hear me speak, nor does the Memo Recorder work, except when an external mic/headset is plugged in.
Thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
I installed a new docking PCB, but the problem is still the same.
I can hear the caller, but the caller cannot hear me.
In addition to that the Memo Recorder on the IPhone does not record any sound - except when I plug in an external mic.
Could there be a problem with the external mic connector in that it has a defect that causes the external mic connection to override the internal mic, always?
von
that sounds baaaaaaad - can you tell me sonething about the phones history? fluid damages, dropped, overrun... - if the internal mic isn't working, but the earpiece is (we have to rule out that the phone isn't stuck in headphone mode) also the speaker/buzzer in the dock is working normal - then there is a problem with the audio codec ic or the connection between the dock connector and the audio ic
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I disagree with rab, since the microphone does not work - the dock connector neeeds to be replaced.
here is the part
and here is the guide
check the guide for the tools you well need to fix the problem
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
If OP can't hear other speak that'd point to the earpiece speaker
von
in his case: "People cannot hear me speak, nor does the Memo Recorder work, except when an external mic/headset is plugged in." - it's the microphone - they don't hear him - so his mic is dead, if he wouldn't hear them - the earpiece would be the dead part
von
Righttt, I need to read these more clearly, I'm doing to delete mine and upvote yours.
von
I'm having same issue. I already tried replacing dock connector. My iPhone have never had any water damage, but I did drop it and thats when it stopped working.
Is there any other suggestions to test what part may be the cause?
Bewertung 0
3 Kommentare:
check cable number 4
von
Markus,
I have checked it numerous times. It seems to be connected right. I also inspected the capacitors/resistors that are in series with it, and they seem ok. Its strange how everything on the dock connector works, except the mic. Not sure what other components are tied to the mic. Perhaps the Audio chip might have a weak pin that isn't making contact. The last resort I can think of to fix this problem is try to re flow the chip with a heat gun. But I'm afraid I might damage other components. Never worked on iPhones before.
von
check the parts in the area around connector 4, anything missing? what kind of heat gun do you use? i used mine a few times on th iphone/ipod touch - but you must be extremely careful - almost every part is underfilled
von
I have the same problem too. I have tried to replace the microphone assemnbly and still didnt work.
Bewertung 0
Antwort hinzufügen
Henri Johnson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 5,925
