Zum Hauptinhalt wechseln
Das Samsung Galaxy S5 mini ist ein Smartphone erschien am 28. Juli 2014. Es ist mit einer 8MP Rückkamera, einem 720p Display, einem Fingerabdruckscanner und einem wasserdichten Gehäuse ausgestattet. Es hat ein größeres Display, längere Akkulaufzeit und eine bessere Kamera als sein älterer Bruder, das Galaxy S4 Mini.
30 Fragen Alle anzeigen
Battery change, increased life
Is it possible to replace the original battery with one with a larger capacity
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
3 Antworten
Hey Chris,
If you see a battery that has a higher mAh then the original Samsung battery, then you should make sure that it is reliable.
Here are some trustworthy sources:
-ZeroLemon
-Seido
-Mugen
-Pacific Power
-Anker
-Batteries + Bulbs
-Spark Fun
-Hope this helped
-Be careful when shopping, I know that I've said that they might be potentially harmful but I said that through my experiences. I've bought three from amazon and one from eBay and they were not reliable. Make sure that you look at the reviews of the product if you are purchasing them.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Why would a battery with a higher mAh be potentially be harmful? Can you explain this?
von
Hilfreichste Antwort
Chris Ford, yes you absolutely can. There are no harmful consequences by using a battery with a higher mAh rating. As long as it fits properly and has the proper connectors. mAh is nothing more than a description of the total amount of energy a battery can store at one time. Since it will last longer, it will also take longer to be charged back to capacity. No other issues with it. Hope this helps, good luck.
Bewertung 1
There's nothing wrong with using a 3rd party battery, for years I have used an Anker 4400mAh battery for my Samsung Galaxy S3. I can't fault it whatsoever, it's been absolutely fantastic and to this day still holds charge well. I would recommend Anker, they're not the most expensive either but have always been reliable for me.
Bewertung 0
Antwort hinzufügen
Chris Ford wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 1,364
