Zum Hauptinhalt wechseln
MDR-ZX100 ZX Series stereo headphones made by Sony.
left side not working
everything seems to be fine with my headphone just my left side of the headphone is not working..
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
sunil gupta, it is either the plug or the connection on the driver (speaker). To test it use a multimeter and place it on ohm reading. Touch the contact, either tip or ring, with one probe and the other probe on the driver. If you have continuity it is the driver if you do not, then it is the plug. Of course, check to make sure the wires are connected on your driver. Use this guide to get to the driver. Here is a guide that shows how to replace the plug. Different headphones, same principle. Hope this helps, good luck.
Skullcandy Lowrider Bild
Anleitung
How to Replace the Audio Jack
Schwierigkeitsgrad:
Mittel
30 minutes - 1 hour
Sony MDR-ZX100 Bild
Anleitung
How to repair Sony MDR-ZX100
Schwierigkeitsgrad:
Mittel
15 - 30 minutes
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
sunil gupta wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 15
Insgesamt: 23,186
