Zum Hauptinhalt wechseln
iPad Mini mit 7,9 Zoll Display und 16, 32 oder 64 GB Speicherkapazität.
630 Fragen Alle anzeigen
Ipad Mini Black Screen After Digitizer Repair
Hello everyone,
I recently cracked my Ipad Mini (Black) glass digitizer. I bough a new digitizer from eTech:
http://www.etechparts.com/Glass-Digitize...
I then heated up the sides and lifted off the screen with spudgers. (I have done this many times with ipad 2's, without any problems) Then I was following a ifixit guide to all of this which did not say to disconnect the battery. So I replaced the digitizer and I thought all was well. I dd not seal it yet though. I then tried to turn it on and saw a dim apple logo and a x near the bottom. I followed a ifix it guide to do the correct soldering. Now when I turn on the ipad I see nothing. But if I hold the home button it says
"siri is not currently available, please connect to the internet" At this point I dont know what to do, please Help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
"I followed a ifix it guide to do the correct soldering."
What? There better not be an iFixit guide that advises you to put a blob of solder in your mini in an attempt to short across a very replaceable filter.
This is an extremely common problem in the iPad mini, and there a dozens of people out there who can replace the backlight fuse for you. Find one and send it to them if hard reset does not solve and the fuse is actually blown.
jessa
War diese Antwort hilfreich?
Bewertung 1
The ifixit guide does tell you to disconnect battery.
If showing up dim images looks like you've blowen the back light
Bewertung 0
This exact same thing happened to me, probably as a result of the ipad inadvertently turning back on as I was removing the broken screen.
Hold the power button and the home button in at the same time for the 10-15 seconds required for a hard reboot. Mine worked just fine after that.
Bewertung 0
Antwort hinzufügen
Aaron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 423
