Zum Hauptinhalt wechseln
Reparaturanleitungen und -Informationen für die Apple Mighty Mouse. Diese Maus ist mit einem Lasersensor, vier Tasten und einem Trackball ausgestattet.
Purchase and replace ball
Something small and hard fell in the mouse track ball area and while i was pressing it (upside down) on a piece of paper to clean it, that little hard piece of dust, carved the surface of my track ball making it unable to scroll without jumping around!
So im now in the need of purchasing a new ball and replacing it! Does the ball as a part exist? Because i can't find anything on ebay! Any help?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
Does anyone know how to find the provider of the scroll ball Apple uses to equip the Mighty mouse?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sadly, the Mighty Mouse and the Magic Mouse are deemed as not repairable by Apple. You're only hope here is to see if you can locate a dead one to steal the part to make yours whole again or look into getting a new one.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Where can i look for a dead one?
von
eBay is a good start, local tech flea markets
von
genik, I am sure that you have already checked these instructions. Post an image of your trackball as well as the damage with your question and lets see if we can assist you finding what you need. If you can measure the diameter of the ball and let us know what you find. the scroll ball is nothing but a "rubber" ball with a metal core. I would suggest to measure the existing ball and get something the same (or at least very close to it) ball from places like this. Hope this helps, good luck.
update
any mechanic or machinist should be able to help you. All you need is a set of vernier calipers to measure it.
Update (01/06/2016)
I thought by now you had found what you needed. Anyhow, the diameter is 7.15mm/0.2815inch
Bewertung 3
6 Kommentare:
Hmm interesting, only i don't know how to measure exactly the diameter!
von
Is this tool offered in the Pro Tech Toolkit? Cause i see something similar... i think!
von
Has anyone managed to measure the diameter of the scroll ball?
von
genik, I sure would have thought you had it accomplished by now. I do have one left, so let me know if you want it:-)
von
You have what left? A scroll ball?
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
genik wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 719
