Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1204 Fragen Alle anzeigen
Can RAM that isn't Mac specific be harmful to your Mac?
While doing some research on RAM for an upgrade from 4 to 6 Gigs I realized that KIngston has "Mac Specific" RAM. When i Purchased my 2x2GB sticks i made sure the specifications were correct and so far no problems. But, from what I read in a post here one of the patrons mentioned that not having Mac specified RAM can cause problems in the long run. Is this true? what can happen? what signs should i look out for if so?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
I purchased my first Kingston RAM at Walmart for $130 for the pair, which i thought was very cheap. But didn't specify wether the RAM is PC or Mac.
von
Thanks for the info. guys. Good to know this stuff being that im pretty new to Mac. :o)
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
yes - there where "mac specific" ram's on the market, but that's history - today - the technical difference between a mac and a pc mainboard is the EFI/BIOS - the rest is very similar/identical - i have an asus eee pc that is convinced that it is a MacBook air, my vaio p thinks that it is a MacBook and my aopen digital engine is a MacBook Pro - they are using in large parts the same components.
surely - using ultra noname ram with noname chips would always led to problems. but many noname ram's are also using nanya or hynix memory chips. using rams within the specifications of the logic board and it will work
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
What do you mean by it thinks its a MacBook Air? Does this mean that you can you install OS X in it?
von
yes, my eee 1005ha and my vaio p have 10.6.2 installed. i had to change the wifi card on the eee, but that was it. my vaio p's wifi, 3g and gps is working without any problem, the gps can be used with the igo8 pc version and wine. the only downside of the vaio p is the gpu - there is no kext for it, i hope that someone hacks the iPhone 3GS "driver" (it has the same gpu as the vaio p)
von
Hilfreichste Antwort
Whenever I buy RAM for a friend or client, I always skip the "Mac specific" because I always saw that as a way to make more money from people that don't know that their macs run at 1066 MHz (Or lower for older macs).
I have always used Corsair or Crucial RAM in macs and I have not seen any problems whatsoever
Bewertung 4
1 Kommentar:
Thanks Gabe ++ I have used Kington RAM and thumb drives before and never had any problems. I hear those names being thrown out there by many people, so obviously its good RAM. But Kingston is pretty good, and cheaper. lol
von
Antwort hinzufügen
Majesty wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 1,281
