Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Frage geschlossen
What is work of U18_RF in iPhone 4s?
I want to know that what is work of Baseband Power Diode U18_RF in iphone 4s?
Ist dies eine gute Frage?
Bewertung 0
6 Kommentare
Jay, you want to know how to replace the IC?
von
No but I also want to know replacing idea.When I heat the ic upper part broke and internal material still jointed with pcb.How could I completely remove ic from pcb.and please also provide main work of this ic in iphone 4s.
One thing more: From where can I buy U3_RF for 4s?
von
Hang on, you tried to reflow and overheated the IC? It melted on the board? Post images of this with your question. That way we can see what you see
von
Oh I can understand about image but not possible now ,because i'm out of town.I think ic not properly melting,any liquid or paste required for easily removing?
von
Jay, have you done a reball before?
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Take it off with some flux and an iron. U18_RF is some sort of baseband logic gate. If it is gone, the phone will always be searching, it is one of the common 4S battery pry damage faults that will result in a phone always searching and not producing an IMEI.
You need to replace it.
Try to avoid using hot air on tiny phone boards if possible. The likelihood of doing more harm than good is too high. It is not necessary to use any hot air to remove and replace this component.
jessa
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks for very useful response.
How do i confirm about this ic is this working or bad.
My iphone not searching. . but No service problem.
von
this ic change to restored error 48 and all error problem solved
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,671
