Zum Hauptinhalt wechseln
Angekündigt am 22. Oktober und erschienen am 13. November 2013. Das iPad mini 2 bringt die Pixelanzahl des iPad Air auf nur 7,9 Zoll unter.
No picture on LCD but backlight works
I'm currently working on an iPad Mini Retina wifi and can't figure out why there's no picture on the LCD but the backlight works. It's clear as day that it's lit but nothing shows up. The device syncs to iTunes but I think it needs to be unlocked or something since it won't let me in.
I've tried multiple LCD's and the exact same thing. Not sure what else could be wrong. I'm assuming it could be a fuse or resistor on the motherboard but I don't know which one or where to search for it. I'm assuming it's next to the flex connectors on the motherboard. If so how in the world do I test those? They're like the size of lint!
Please help!
Ist dies eine gute Frage?
Bewertung 5
5 Kommentare
No clue anyone?
von
von
Did you ever find a solution to this? I am experiencing the same problem now.
von
I have this same problem. If I plug back in the old LCD it has a picture. But the new LCD only the backlight comes on, no picture.
von
has anyone had a solution for this?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Tap around the back of the frame. Sometimes this causes it to come back on, for whatever reason
War diese Antwort hilfreich?
Bewertung 1
maybe you did not connect the ribbon cable in all the way sometimes that the culprit . sometimes we get in a hurry putting thing back together. or could bent it jus a little.
Bewertung 0
Antwort hinzufügen
npham54 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 1,719
