Joe, not sure what happened to your iPad, but this is going to be a major repair. If you think its to small for your camera, just wait till you have to solder those components back. You also want to clean your board properly with some isopropyl alcohol. Looks pretty bad around the missing components. Anyway here is the list of the missing components. I thought it might be easier to point out the ones on the good image:"
Reference designator L2202 is a 90OHM 50MA TCM0605 filter choke
Reference designator L2232 is a 90OHM 50MA TCM0605 filter choke
Reference designator L2222 is a 90OHM 50MA TCM0605 filter choke
Reference designator L2212 is a 90OHM 50MA TCM0605 filter choke
Reference designator R2200 is a 10K 1/20W 5% resistor in a 201 package
Reference designator R2201 is a 10K 1/20W 5% resistor in a 201 package
Reference designator C2200 is a 1000pF 16V 10% capacitor in a 201 package
Reference designator C2231 is a 82pF 25V 10% capacitor in a 201 package
Reference designator C2232 is a 82pF 25V 10% capacitor in a 201 package
Reference designator C2206 is a 1000pF 16V 10% capacitor in a 201 package
As to where to get those parts, this will depend on where you are located. I prefer Mouser.com or Digikey.com but others have those as well. the filter chokes can be a bit of a pain to be found. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
Can you give us the last four digits of your serial number as Apple has a few different versions.
von Dan
Joe, besides getting a proper model, I also suggest to post images of your board with your question. There are lots of "little chips" in that vicinity.
von oldturkey03
The model is iPad 2 : A1395.
Here is my best attempt at taking a picture. The board is so small my camera struggles to focus getting any closer.
http://www.joecullen.net/ifixit/iPad%202...
I have been able to access the data via a computer so it is all working. Just the LCD has nothing on it (I have also tried a new LCD).
I realise that fixing my problem is going to be hard. Any help will be most appreciated.
von Joe
