Zum Hauptinhalt wechseln
CDMA Version des iPhones der vierten Generation. Die Reparatur ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. Modell A1349 mit 16 oder 32 GB, CDMA Kompabilität.
295 Fragen Alle anzeigen
Frage geschlossen
iPhone will not power on unless power flex is unplugged
Hello!
I replaced the LCD/Digitizer on the iphone 4 cdma phone and unfortunately used a defective screen without knowing.. I think.. The screen turned on once and it was pyscadelic looking at best for about 2 seconds and shut off..
Now what happens is the phone will not power on unless the power/mic/prox sensor is unplugged. (with a replacement lcd/digi)
Just ordered a power flex cable.. Do you think it will fix my issue? Anything else I can try in the mean time?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There are three possibilities causing the problem:
1. The power button sucked in and kept pressing the contactor.
2. The power key contactor on the flex sucked in.
3. Improper position to place the flex, which causes the press.
So when you place the new power flex cable, you should pay attention to the position and the power button to avoiding kinds of pressing.
Good luck to you!
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I replaced the power button flex cable and it fixed it. Yay!
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 59
