What are the hardware differences between model A1522 and A1524
I am curious as to what chips are different because it seems like a1524 just has more lte bands from the tech specs on Apple's website.
Ist dies eine gute Frage?
There are four models of the iPhone 6 Plus phone (I've only listed the ones you will likely see). Different countries have different cellular networks. Per EveryMac:
As far as the chips involved:
Depending on the model one or more of these chips are different to cover the different bands. As the IFIXIT crew flew to Australia to crack open the very first available units I suspect models they took apart was the Sprint/Global (I could be wrong).
War diese Antwort hilfreich?
I guess I am actually wondering if there is a hardware difference at all between a1522 and a1524 because it seems odd that they would have two models if they just added four lte bands to the global/ Sprint version. I think the hardware for the Verizon /att/t-mobile is all the same (a1522), unless I am mistaken.
A1522 and A1524 use the same firmware, it's a reason to believe they use the same hardware.
However I saw in the iPhone 5s circuit diagram that there are different PA ID resistors for the same models, maybe it's just a BOM option thing or they actually use these resistors to lock out different network configs.
I'm sending a 6+ to a friend in Thailand Is the A1522 OK or should I get an A1524
I guess you should send the A1624
I am using one in Uganda (East Africa) and it has worked well through Asia and the Middle East.
You can see the differences among all iPhone 6 models (A1549, A1586, A1589, A1522, A1524 and A1593) here:
http://www.techwalls.com/differences-bet...
Hope it helps
I'm using CDMA/Verizon iPhone 6 Plus 128GB, all the IPSW files I have down loaded so far are not compatible with mine.
Is there any place I can find my specific CDMA/Verizon 6 Plus 128GB IPSW file to download?
My model number is A1522 and MGCN2LL/A
Thanks, SAK
I am from central Asia and today I saw a new Iphone 6+, but its demo version with sim-slot. They are selling it for cheap price. So, I am curious is it possible to make it normal one and use it?
See if a friend of yours who has an iPhone will let you borrow their SIM to put into this phone. Once the SIM is in place your phone should work, if not it is either not compatible to your carriers services in your area or is locked out as it was likely stolen.
I see on YouTube how they switch chips to do a hardware iCloud unlock. My question is if I can take the chips from an T-Mobile iPhone 6 and use them on an Sprint iPhone 6 Plus? Any thoughts or ideas would be great.
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 32
Insgesamt: 69,551
1 Kommentar
My Iphone 6 plus ( A1524 ) having problem. i am using maxis. Network is too slow in Port Dickson.
von hari5015
