Zum Hauptinhalt wechseln
Repair guides and support for top and front loading Whirlpool brand washers.
How can I address the F1 error code?
My Cabrio washing machine constantly stops during the wash cycle and shows an F1 error code. I hit pause and start at least 50 times over two hours to complete my wash. Is there a part I can replace so that my wash cycle operates properly?
Ist dies eine gute Frage?
Bewertung 12
4 Kommentare
An Luther then the f1 error code at the same time e9 appears an door will not open
von
i have a washer the front loader and when i press start it dosnt even do anything just f1
von
What if it just shows an f flashing?
von
Cabrio washer..error code F1 and E5. Unplugged for 15 min…then it blinked 888. Don’t know wha to do?
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Usually, it's a problem with the control board. By replacing the control board, you should be able to fix the problem. However, it might also be a problem with the hose, something might be stuck in the hose. There is even a web site dedicated to the F1 error :) Whirlpool F1 Error web site. There you can find detailed instructions on how to check and clean the hose or if needed, replace the control board and also where to buy a proper one.
War diese Antwort hilfreich?
Bewertung 3
I had the same issue. I replaced the board and the F1 error was still there. I decided to put a hose clamp on the hose coming from the board. Boom my F1 error is gone. Hope this helps.
Bewertung 1
2 Kommentare:
I hope this is will work. Which hose is it?
von
It worked for me, my wife and I are very thankful for your post. I connected the hose, ran the diagnostic mode, fixed. We’re washing clothes!
von
Common, Water Pump. ( Clogged or Broken )
to get door to open, use wet-dry vacume to pull water out from washer, by vacumming water out from drain hose. ( the tube that goes to the hole in your wall. =-D)
Soap dispenser Missing Magnet sensor, or soap dispenser is not all the way in.
Motor control Unit is bad, or door lock solenoid is damaged.
Bewertung 0
2 Kommentare:
Drain pump. (take wet dry vac-vacume water out of washer through drain hose)
try machine again.) works( replace pump)
soap dispenser bad or half out.
bad motor control or door lock solenoid is bad replace door lock.
von
I have a Cabrio Washer, Replaced the Control Board and the washer wont do anything. I am at a loss.
von
A friend of mine had the same issue F1 code. We tried to unplug for 10 minutes and plugged it in about 6 or 7 times. We checked the breaker box a couple times, didn't realize one side of the double breaker was f##@ed. Changed out the breaker. No problems.
Bewertung 0
Antwort hinzufügen
Bob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 39
Letzte 30 Tage: 208
Insgesamt: 95,108
