Zum Hauptinhalt wechseln
Die fünfte, auf Android basierende Generation der Galaxy Smartphones von Samsung ist seit dem 11. April 2014 auf dem Markt. Zu den Verbesserungen gehören der Fingerabdruckscanner, eine erneuerte Kamera, ein größeres Display und Wasserresistenz. Es ist in vier verschiedenen Farben verfügbar: Schwarz, blau, weiß und kupfer.
577 Fragen Alle anzeigen
Soft button cable torn during digitizer replacement, options?
I was taking the screen assembly off of an S5. Well, the warning in the guide was right:
"These cables are thin and easily damaged, therefore be certain you are only peeling them off the display assembly and not lacerating them."
Since the entire front of the device was thoroughly shattered, I was pulling individual shards of glass from the strip of adhesive. In the process of doing that for the left soft button, it tore off. I can't seem to find any replacement parts for that, and I'm wondering if the device has any chance of functioning without it. I certainly don't mind just switching to screen soft buttons, but if there's a chance to replace the part I'd like to go for that.
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The soft keys comes together with the whole charging flex just like that http://www.witrigs.com/oem-charging-port... , so if you want to replace, you need to replace the whole assembly.
Attention: You should notice the version of you S5 very much, because the charging port assembly are different among different versions.
War diese Antwort hilfreich?
Bewertung 3
Hi,
I have the same problem.. my phone screen went off when i dropped it on the floor.. so i had to replace it.. the technician said.. so thats what i did!.. later when i had my phone back "fixed" the soft left button stopped working.
Is there maybe another way to utilise it from settings menu? Or how to access the task manager without using the left soft button?
Bewertung 0
Antwort hinzufügen
Joey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 7,293
