Zum Hauptinhalt wechseln
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 Fragen Alle anzeigen
Why is my phone's sound not working?
My phone has stopped playing any type of sound that would normally play. I have made sure the volume is up with my volume controls.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 148
39 Kommentare
does it ring when receiving calls?
von
My phone isn't working I tried to turn up all my volumes and see if it works .... And NOTHING !!
von
my phone is not working(dead),what can ido?
von
On my HTC One Remix, my sound did exactly what yours did, but i realized when i turn it off for two days, then decrypt it, it somehow works again, but not long after it does the same thing again. someone please explain how i can fix it.
von
I have the same problem except on my tablet it used to only work with headphones but now it has no sound whatsoever!!!!!! I need help.
von
34 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Your phone sounds could not be working because of something simple, or your phone needing a repair. First, check to see if your sound is up. Phones have multiple volumes for different things so be sure to turn up the right one or just turn up all of them to see which one is for what. Second, make sure sound is suppose to be playing. A lot of times, the phone will stop the sound if it needs time to buffer or if the app does not want to work. Give it time and try something else that you know plays sound like a ringtone. Third, if neither of those are right, then your speaker may be blown. Check out our troubleshooting page at HTC One M7 Troubleshooting for more help on your speaker being blown.
War diese Antwort hilfreich?
Bewertung 54
28 Kommentare:
I was listening to music and tgen all of a sudden in the middle of a song the sound stoped and it hasent worked since
von
I was listening to music on YouTube and all the sudden my phone stopped working
von
I tried every possible thing and nothing
von
Does steam affect your speaker
von
Hola.my phone fell in coco puffs
von
23 weitere Kommentare anzeigen
If sound is not working of your phone so may be your phone speaker could be damage.
Bewertung 25
9 Kommentare:
My phone is doing the same but I don't think something is wrong with the speakers because I am not even able to play anything with sound.... It either doesn't play or shows something went wrong if I try opening a video...... Also no other sounds are working like Touch sounds... Msg... Calls... When I try calling someone using wifi it shows make sure you have an internet connection even when I am connected to the Internet
von
when i go into camera and test my sound and my friend speaks i can hardly hear meh friend
von
Hi uzmasyed55 - I am facing the same issue on my HTC M9. Did you find any solution to your's?
von
my speaker is still working because alarms play but youtube videos and music dont have sound
von
Mine too!! All videos and YouTube sounds are very low. I was able to talk on the phone though. Help!!!! I’m not technologically Smart
von
if you put your phone into boot loader (look up on youtube if you don't know) and go down to recovery mode using the volume up and the volume down buttons and hit the power button on it your phone should be in a black screen for 5 - 10 seconds then an android will a red charge or red battery will pop up (don't worry that doesn't mean you have low battery) hold down the power button and the volume up, after that you should into another different screen scroll down using the volume down button and hit the power button on wipe cache partition (don't worry it does not break your phone or do anything bad all it does is stores temporary system data it's supposed to allow the system to access apps more quickly and efficiently but sometimes things get cluttered and outdated so a periodic cache clearing can help make the system run more smoothly if you don't believe me you can google it "what does wipe cache partition mean?" after you do that it should pop up with the same screen as last time and it should say reboot system now all you do is press the power button and it should reboot your phone and after test if it works if not do it again if still not working please feel free to ask me for more help (i did copy and paste what wiping cache partition mean because i forgot it at the time.
Bewertung 8
3 Kommentare:
Somebody please help me!!! I just bought this Samsung Galaxy J7 a few weeks ago. My volume is up on all apps but there is a note under the settings that reads "Mute all sounds". I think this 16 year old did something to my phone! I cannot even hear the dialing and ringing when I call anyone much less even hear them when they pick up. What do I do?
von
Mine is the same. Only got this phone the other day
von
Having the same issue too, can someone come to my rescue please 🥺🥺💔
von
Disable some tmob bloat,all live wallpapers,amazon,dropbox for HTC sense.no issue since.HTC one sense.all sound back to norm
Bewertung 4
1 Kommentar:
12/22/15 cross my fingers lol
von
AJ,
I've owned an HTC One M7 in the past. There are 2 things that kept going bad on it.
a) the camera turns purple
b) the headphone jack breaks in stupid ways
Check your FM RADIO app or download the Next RADIO App.
If you launch it, and it doesn't ask you to plug in a headphone (to use as the antenna), then that is your problem. The headphone jack is engineered to fail, and it may think you have something plugged in so there is no sound on real speakers.
A workaround to your frustration (albeit a horrible one) would be to switch to bluetooth altogether.
Bewertung 4
2 Kommentare:
Why my phone Alcatel if I make phone the people on the line no hear my voice? Plz answer thank u
von
This is not working ya
von
I have had this problem a number of times, I think by pressing the buttons in a certain combination it turns on 'do not disturb’ mode. Turn this off in sound settings and it should work again.
Bewertung 3
1 Kommentar:
Does it work for smartphones?
von
What type of headphones does the stratus c5 elite use
Bewertung 0
Antwort hinzufügen
AJ Skiles wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 85
Letzte 30 Tage: 219
Insgesamt: 306,033
