Zum Hauptinhalt wechseln
The Commodore 64 was released in August 1982 and was met with huge success. In March of 1987 the Commodore 64C was released.
What port do I use to connect my Commodore 64 joystick?
I have a joystick for my Commodore 64, but I don't know which port it connects to.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I always used the Atari 2600 joysticks with the C64. I remember playing Spy Hunter and it had a special plastic controller holder so you could use two joysticks and be able to press both buttons with the left hand.
http://atariage.com/forums/uploads/month...
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You should always use Port 2, because joysticks plugged into Port 1 could interfere with the command line interface. Some people thought this port was plugging a second joystick for two player games, however, this port became the default after a while.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Both ports go to the same pins on the CIA that handles the keyboard matrix, so a joystick plugged into either port can interfere with key scanning. But this is a moot point with software designed to handle joystick input.
von
The answer depends on which port the game or application expects it to be plugged into. See its documentation. There is no risk of damage in trying them both; just be sure to turn the C64 off before unplugging and plugging them in.
Both ports go to the same pins on the IC that handles the interface with the keyboard matrix, so potentially a joystick plugged into either port can interfere with key scanning. But this is a moot point with software designed to handle joystick input.
Bewertung 0
Antwort hinzufügen
Adam Kowaleski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 1,106
