Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
unknown component in the bottom of the dock connector
Hello. I would like to know what kind of component that's what came off. It was close to the pitches of the speaker.
Thanks
Ciao. Vorrei sapere che tipo di componente è questo che si è staccato. Era vicino alle piazzole dello speaker.
Grazie
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Is it metal? Are you replacing anything? It looks like it's a piece of foam from something you were trying to replace. Is that correct?
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you for your response.
I think it's a capacitor or an inductor, but the pins are damaged and can not weld it again and I have to replace it.
It was removed because the "technician" who preceded me glued to the motherboard with cyanoacrylate glue ...
Grazie per la tua risposta.
Io credo sia un condensatore o una induttanza, ma i pin sono rovinati e non posso saldarlo di nuovo e devo sostituirlo.
Si è staccato perchè il "tecnico" che mi ha preceduto ha incollato la scheda madre con colla cianoacrilato...
von
Antwort hinzufügen
aintel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 79
