Zum Hauptinhalt wechseln
Reparaturanleitungen für Netbooks
Screen replacement for Nextbook 8 NX785QC8G
I recently dropped my Nextbook 8 and the Digitizer broke, I need to replace it but I don't know how to take it apart since it has no screws on the outside. I also need a link to a new digitizer screen because I'm not sure as to which one it needs. Thank you for your help!
Ist dies eine gute Frage?
Bewertung 14
1 Kommentar
Where can I buy a screen for it
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
You could buy a new digitizer from ebay
New-Digitizer-Touch-Screen-Panel-For-Nex...
War diese Antwort hilfreich?
Bewertung 3
if you look at the edge of the tablet there's a seam. you want to get a really tiny screwdriver and slow try to open it. when you hear a pop that means the clips on the inside have released and you want to do that all the way around the side of the tablet.
By,Jahn Peabody
Bewertung 2
1 Kommentar:
After I put it back together the touch screen is not working and it w
as before. No I have not replaced the screen as of yet.
von
I think I'm having the same problem. Dropped my nextbook and it is cracked across the screen. It's crack left to right at the middle of the tablet. I can't use the top portion because the touch screen isn't working on the top. Bellow the crack it's fine. How would I go about replacing it when I get the screen replacement?
Bewertung 1
Yes how much it cost to replace it
Bewertung 0
How to fix the part were the charger goes into the nextbook
Bewertung 0
Antwort hinzufügen
Alexander wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 28
Insgesamt: 5,826
