Zum Hauptinhalt wechseln
Buick Century is the model name used by Buick for a line of upscale performance cars from 1936 to 1942 and 1954 to 1958, and from 1973 to 2005 for a mid-size car.
36 Fragen Alle anzeigen
No odometer light, other drl functions ok on 1997-2005 Buick Century?
no odometer illuminate, can't see milage
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 11
7 Kommentare
I had the same problem. Before resorting to taking everything apart, try pressing the trip odometer reset button. I was curious to see if it would work. Apparently, changing the display from ODO to Trip ODO, reset the circuit. My display is working without replacing the resistors or taking my dash apart!
von
yeah but more commonly you will need to perform repair
von
dude....you're a genius. it worked!!!!
von
Worked for me too! Who says there is nothing good on the internet!!!! Thanks Jeremy!!
von
Didn't work for me? I have a 2000 Chrysler Town and country changed the cluster board, but still nothing? Help and no gauges?
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
9 Antworten
Gewählte Lösung
Here is a link to aforum discuion and cure for your problem Good luck Ralph
http://www.realworldautomotive.com/forum...
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
+ good
von
Try pressing the ODO/Trip ODO button first. It resets the circuit. My light came back on as soon as I tried it. It will save you much time and headache!
Bewertung 3
just a couple of bad resistors, cost me $1 for a pack of 5, and you only have to replace 4 of them. http://www.youtube.com/watch?v=84FAjLxoK... that'll talk you through it
Bewertung 2
3 Kommentare:
+ good answer.
von
mine had 3 of 4 and need replacement
von
What is the wattage for the 150 ohm resistors to buy?
von
Fixed it last night after watching a youtube video http://youtu.be/ebTS25sNOHQ buying a 5 pk of resisters at Radio Shack and watching a video on how to solder and purchasing a soldering iron and metal to solder. soldering http://youtu.be/I_NU2ruzyc4
Bewertung 0
This happened in my car, the above links are true. There are some crappy resistors inside of the instrument panel, replace them and you are good to go!
Bewertung 0
1 Kommentar:
Havent tried yet but im going to. Im going to have to take dash apart. Pushing button doent work for me. i dred it.
von
The reset button works but then it cuts back off evertime i start the car back up
Bewertung 0
Didnit continue to track miles while it was out? I may be buying a Buick that has this issue. The sticker on the window says oil change is due in a couple weeks or 89,000 miles. I’m curious if I fix it, if it will show 127k on the odometer meaning the guy had the sticker made up or if the sticker is legit, it will show the ~89k on the odometer.
Basically, my question is, if it burned out at 100 miles and you drove for 300 miles then fixed it, will it show 100 miles or the correct 400 Miles?
Bewertung 0
1 Kommentar:
I know this comment is from 3 years ago, but it still tracks mile. Even if the display is out.
von
It will show the correct 400 miles. The failure only involves illumination, not function.
Bewertung 0
1 Kommentar:
What are the specifications of that resistors?
von
Worked like a charm! Thanks for the tip! :)
Bewertung 0
Antwort hinzufügen
jerryo80911 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 28
Letzte 30 Tage: 94
Insgesamt: 50,967
