Zum Hauptinhalt wechseln
A professional extra burner. Released in 2008, with model name SB30.
3 Fragen Alle anzeigen
Is it acceptable to use large pots or pans?
I am unsure if it would be safe to use pots and pans larger than the heated surface area.
I've done so on a conventional home oven, but I am worried if this hot plate can even handle the bigger loads.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It won't hurt anything, but it could be not safe as the possibility of the pan/pot spilling over.
The other factor is the transfer of heat will give you a hot area unless your pan/pot is clad with a Copper or Aluminum core to smooth out the hot spot.
You will also need to think about the volume you are heating here. Boiling a large pot of water will take longer and it may not be able to sustain (recover) the boil. Review the BTU's of the heat plate.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
kevin phan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 91
