Zum Hauptinhalt wechseln
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185 Fragen Alle anzeigen
screen black but touch works..
I have changed the screen on my LG G2 and it went well. Now when I start it the touch works but the screen is completely black (I hear that I can unlock the lock screen) What should I do about this?
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
After replacing the screen on the LG G2 you need to do a soft reset. Hold the power button and the down volume button simultaneously to do this. The screen should work now. If not, it's likely an issue with the connections inside, or maybe you pinched/ripped one of the cables on the new screen.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Your answers are very good. Please complete your profile so we can get to know you better ;-)
von
Check if the LCD connector get loosen and replug it. At the same time, check if the flex cable or connector is broken.
And the most serious result after trying above is your phone is broken again.
Bewertung 0
Antwort hinzufügen
Jonas Lindberg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 374
