Zum Hauptinhalt wechseln
This device is part of the second wave of Polaroid's 600 series cameras that were developed between the 1980's and 1990's. It would instantly develop the film in about three minutes and the battery was integrated into the film pack.
15 Fragen Alle anzeigen
Why aren't my pictures developing?
I am taking pictures and the flash is engaging. The camera ejects a picture, but the picture isn't developing.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 26
7 Kommentare
I got one for christmas, and i tried taking 3 pics, none of them devolped, it is kinda cold in my room does that have to do with it
von
how did you fix it? bc mine has that problem too & idk if its broken
von
I got a polaroid 7's camera and when I take the pic and print it I let it be for a while but nothing shows up
von
i got a polaroid 10 cameraand it wont
show up
von
I have the instax mini 7s and I took two pictures with the indoor setting and one with the fine setting and they all came out blank
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
17 Antworten
Gewählte Lösung
It is always possible that the temperature is not ideal for the picture to develop. If you are using the film originally designed for the camera then the film is really old and not likely to work. If you are using the Impossible film then the film is very experimental and very sensitive to its surroundings. You don't want it to be too hot or too cold. In the directions of the film is says that at an ideal temperature of 70 degrees Fahrenheit it will take the pictures about 10 minutes to develop.
Here are a couple other resources for troubleshooting similar cameras that might help:
Polaroid Onestep Close Up Troubleshooting
Instax Mini film not developing
War diese Antwort hilfreich?
Bewertung 13
I just took one with the flash and it printed fine, then I took 2 more right after and nothing is showing
Bewertung 6
3 Kommentare:
That’s exactly what happened to me I just got the camera and film today.
von
Flash needs to be on, unless your environment around the subject is extremely lit up
von
i got mine today and i printed only 7 and the other 6 did not work
von
everytime i use the polaroid the pictyre will came out with nothing. It is not developing... I need help
Bewertung 3
4 Kommentare:
Usually for me, it takes about 3 minutes max for my Instax 8 Polaroid pictures to develop. However, this time I have taken the picture and 15 minutes later it's still not developed. I have taken three today and two have turned a peach colour and no other shapes are formed- the entire picture is peach and my third one has some spots of the picture on it but it still has not fully come through within 15 minutes. Help!!
von
Well maybe you are taking the picture in the dark, because if you take it in the dark it will not show up
von
I just started im new i took one with my dog and mine is a black pic it wont show up
von
Your film could have possibly expired, unused film even in it's sealed packaging won't last more than usually 5 to 10 year's. If you try to use film 5 to 10 year's after it expired the photo's will either be very faint and or tingish/orangeish or absolutely nothing at all. You can buy new film at Polaroid Immposibles.Com or at Target Department Store's in the Electronic's department but it's a little expensive though.
von
If it is not working , it is probaly to hot. Try puting it in the fridge for NO MORE then 1-3 minutes.
Bewertung 2
You have to let it in the dark so it can develop at least 5 to 10 minutes if not developing shake it for 10 seconds and then put it back in the dark for 5 to 10 minutes if not developed by then shake it more for 10 minutes and if not developed then leave over night
Bewertung 1
3 Kommentare:
it does help by the way
von
Don’t shake it! Shaking it won’t do anything. If you shake it the photo will not come out.
von
Shaking it will cause spots in the picture; if you shake it too much. If you do a little its fine (it wont really effect it), but shaking hard or for too long will ruin the image and wont develop clearly.
von
Check your rollers. At the bottom of the Polaroid film is the big white rectangle, this is where the chemicals are stored. If your rollers are dirty or glazed then they won't spread the emulsifier correctly and your prints won't come out. Open your camera with no film in it, and clean the rollers with rubbing alcohol, the stronger the better. Use cotton swabs. Chemicals get all over them and gum them up. Clean them and check that they are rolling well. Make sure your film cartridge is well seated and then try again.
Don't shake the film it doesn't do anything.
Bewertung 1
It has happened to me to. Its Okay Guys! Calm Down. The Film Is Probably Older Than The Other Films You Have. Or Maybe Its Just Malfunctioning. Y'know You Can Just Get Another Pack. I Got Another And It Worked Again. But If You Dont Want To Waste Money, Try Other Methods To Fix Your Problem! Okay Thats It.
Bewertung 0
The same thing is happening to me. The film I have is brand new, and I'm at the beach in GREAT lighting trying to take pictures of myself, the sky, and the water. Nothing is showing up and I've taken 4.
Bewertung 0
1 Kommentar:
same exact thing happened to me, but the film isnt even coming out. I hear the shutter and the flash is there, but the picture just doesnt come out
von
Same for me. Probably cause i ran out of film in 2001. Check if you ran out of film
Bewertung 0
1 Kommentar:
the film is brand new
von
Mine is showing white but no picture I took it a few hours ago
Bewertung 0
2 Kommentare:
mine also I dont know what tio do... But it is over 70 degrees and i dont know if that has to do with anything someone help I just got it yestrday
von
The same thing happened to one of my films but of you take another one it should show if that’s the case
von
Using the Polaroid original film it can take up to 15 minutes for a film to develop properly. Once you’ve taken a picture immediately put it somewhere dark as they are still very sensitive to light for a few seconds. Check it after a few minutes. NEVER SHAKE THE PICTURE!!!
If the pictures are blank it could be that the rollers in the camera have become loose so aren’t properly rupturing the chemical tab, this will normally result in a kind of yellowy square where the picture should be.
If it’s all white try using the expose slider on the camera to darken the next image.
Bewertung 0
1 Kommentar:
My phone picture are not coming out in colors just a fade
von
This same thing happened to me… Everyone told me to shake it and leave it in the sun. Don’t do that! That will make it too hot. Instead, leave it facing down in a dark, room temp room and it should develop. If still not working and it’s the first pic in that film cartridge, it might be because the company buts a black starter to make sure your camera is working properly. If it is the first pic and the tester doesn’t come out, than you might have to open the back of your camera (where you place the film) take out the film (if you have in already) and you shall see a little rectangle. If the rectangle is dirty, simply add some baby oil on a Cotten ball and wipe the rectangle gentally . Please comment if none of this works and I’ll do some research.
Bewertung 0
1 Kommentar:
I mean at leave overnight and rubbing alcohol not baby oil
von
You have to remember that once it ejects the film cover after you have I started a new film pack, you CANNOT open the back cover (the place where you put the film) again because once the film cover is opened the photos are vulnerable and if they are exposed to any light before you have used them for a picture, all of the film will be ruined and unusable. Hope that helps.
Bewertung 0
you have to wait about 10 minutes for the picture to fully generate. Some people say that heat light and shaking it can help this situation.
Bewertung 0
1 Kommentar:
How old is your camera my fun comes out in like 30-40 seconds
von
It'll take a few minutes to develop
Bewertung 0
please someone help i took a pic and set it down then put it in a dark place and black dots are appering help i have wasted 8 film and i dont want to waste them plese someone help if you helpthat would really make my day
Bewertung 0
It seems that this is an all too common issue and that means fujifilm needs to do something to fix this huge problem!!!
Bewertung 0
1 Kommentar:
Most of these posts are about vintage Polaroid cameras and Impossible Film.
von
Antwort hinzufügen
Tyler OBrien wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 15
Letzte 7 Tage: 82
Letzte 30 Tage: 386
Insgesamt: 204,548
