Zum Hauptinhalt wechseln
The HP Photosmart Premium All-in-One printer can be used as a printer, copier, scanner. This printer uses a 5 color print system.
How can I improve the quality of printing?
The quality of the image is not acceptable. How Can I improve the quality? I made sure the ink cartridge levels are good.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would recommend checking the levels of the ink to be your first step. If they appear to be fine then you may need to replace the printhead. You can see our guide on how to replace the printhead.
If your levels of ink are low you should replace the ink cartridges which is also shown in our guide.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
You could also clean the printer head as the printer head can get clogged with gunk. Google "how to clean printer head" and go from there.
von
Antwort hinzufügen
Laura wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 396
