Zum Hauptinhalt wechseln
Das Samsung Galaxy S3 ist ein Smartphone mit Multitouch- und Drahtlosladefunktion, ist Eyetracking-fähig und hat einen vergrößerten Speicher.
459 Fragen Alle anzeigen
LCD screen won't light up
Hi there,
I dropped my Samsung s3 and although there is no external damage, the LCD light won't turn on and it's black, even tho I can still turn the phone off and on and can still hear when a txt etc is received.
How can I get my screen to work again?
Thanks!
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi,
90% your display is broken.
If you want, you can open the phone and reconnect the Display Flex Cable (Step 19):
Samsung Galaxy S III Front Panel Einheit ersetzen
Next, you need a Display assembly replacement.
Regards.
War diese Antwort hilfreich?
Bewertung 2
Hello i have the same problem.. but mine is with s6 edge. And also with broken LCD glass.. i cant afford to get a new LCD yet.
But i wonder if its the LCD. Or like you said the display flex cable.
Mine lights up sometimes after i press all the bottons a hundred times. But i get tired when it happen.
You think its the same peoblem??
Idk how to open my phone. So.. but i will want for someone to do it for me... but i wanna have idea of the problem so they wont trick me about what else is broken and charge me a lot. Hehehe
Thank you in advance.
Bewertung 0
Antwort hinzufügen
Peetah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 6,688
