Zum Hauptinhalt wechseln
Repair guides for Dell Inspiron laptops. A line of mid-level Dell laptop computers.
20 Fragen Alle anzeigen
What can I upgrade to make this laptop faster?
I recently bought a DELL INSPIRON 15 3000 series laptop MODEL # 3542
I would like to know if there is any parts that I can change or upgrade to make it faster . if there is can you let me know what parts to look for .if someone can give me some advise in regards to that's I would really it .....
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 13
3 Kommentare
I have the same model of the machine in this question. I have the 1.6 Celeron processor, 500gb HDD and 4gb RAM. Dell specs say there is a 4gb RAM limit. Is there any work around to get the MB to recognize 8bg of RAM?
von
If i3 generation laptop yes you can add one more 8 GB RAM.
von
I am a repair facility in Crystal River, FL.; customer has i5 with 8gbyts ddr4 memory; cpu 1.8ghz burst speed; I changed out 1 tb spinner for 240gbyt ssd; now operates almost 40% faster, and load up time is about 26 seconds. That and installing: bitdefender free antivirus; iobit's: malware, advanced system care, uninstaller, and defragger, with "free windows registry repair 4.2," all added to faster load and operating time; all are all freeware.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
The Inspiron 3000 Series/3542 laptop is actually a wide range of laptops, with a wide range of features. We'll really need to know a lot more to give you relevant direction: CPU speed/type, RAM, HD especially. However, there are some no-brainer upgrades that will improve performance (and perceived speed) on any computer.
First step is RAM. The model has anywhere from 2GB to 8GB of DDR3L 1600MHz RAM, in a single stick. If you have 2GB or 4GB now, replace them with 8GB; 4GB is barely enough to get Windows running, and 2GB is just insulting. The limited RAM is made worse by the fact that the graphics module shares system RAM, rather than having its own dedicated memory. This means that when you're doing video-intensive stuff like games or movies, you have even less RAM to run the applications and operating system. iFixit sells a stick that will work, but the RAM is readily available almost anywhere.
Second step is storage. The Inspiron 3000 uses a 2.5" SATA III hard drive, but not a very fast one; the specifications say that all variations use a 5400 RPM platter drive. There are faster drives available, in order of increasing speed: 7200 RPM platter drives, hybrid drives (platter drives with very large RAM caches), and SSD (solid state drives). As you might imagine, the faster you go, the more the drives cost. SSDs usually have much less storage space than platter drives; a 500GB platter drive is well under $100, while a 500GB SSD can be over $300.
It's possible to get both the speed of an SSD and the storage space of a platter drive by replacing the original platter drive with a much-faster SSD, removing the optical drive from its internal bay and installing the original platter drive in that bay, using a special carrier. iFixit has such a carrier. You use the SSD as your system/applications drive, and store all your documents on the platter drive; that way, the things you're running all the time are on the fastest device.
Those are the easy options; after that, speed bumps get a lot harder. If your CPU is mounted in a socket on the logic board, you may be able to remove it and install a faster CPU. But most laptops don't use socketed CPUs; the processor is soldered directly onto the logic board. Even if you could replace it, it's not wise to do so. The cooling system in the laptop was designed to cool down the CPU Dell installed, not the faster/hotter CPU you put in.
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD. Bild
Produkt
Unibody Laptop Dual Drive
$24.99
RAM / 8 GB / PC3L-12800 / Low Profile / 204 pin, 1600 MHz Bild
Produkt
PC3L-12800 8 GB RAM Chip
$44.99
War diese Antwort hilfreich?
Bewertung 9
2 Kommentare:
will the unibody Laptop dual drive work for this specific model?
von
I'm assuming you mean the optical drive carrier, which allows you to install a 2.5" hard drive in an optical drive bay? Then yes, assuming the Inspiron has a SATA optical drive interface and you transfer the existing SATA cable to the replacement drive.
If you were trying to install an Apple Superdrive as a replacement for a dead optical drive in an Inspiron laptop, it's remotely possible that you'd need to install drive-specific drivers from Panasonic/Pioneer/Sony, depending on who manufactured the Superdrive. While OSX includes the necessary drivers for Apple's installed hardware, you won't know whether your version of Windows (Linux, whatever) does the same until you've tried it out.
2.5" SATA hard drives and 5.25" SATA optical drives are essentially generic items with standard interfaces. As long as the cable in the computer fits the drive, the necessary drivers are installed and the drive is formatted correctly, everything should work.
von
These all some hardware steps which can fast your laptop:
1.Install external graphics card. It will increase graphic as well as processing speed too.
2.Increase RAM. In case of increasing RAM you have to check if motherboard is capable to handle the speed of RAM or not.
3.GO to my computer properties>Advance system settings>performance under Advance Tab> then go to advance >change virtual memory> Increase Virtual memory it will partially gives you better processing speed of windows which makes computer faster.
Thanks.
Bewertung 3
1 Kommentar:
You cant replace GPU in this laptop its only in gaming laptops.
von
Upgrade your hard drive (Hhd) to solid state drive (ssd)
Bewertung 1
Install a Solid State Drive. Inexpensive and makes the biggest difference. The RAM helps only a little bit.
Bewertung 0
Antwort hinzufügen
Ralph wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 62,146
