Zum Hauptinhalt wechseln
Model M7572 / 400 or 500 MHz G3 processor
45 Fragen Alle anzeigen
Motherboard replacement.
Is it possible to get to the motherboard to remove and replace, from the rear of the powerbook? All the instructions I see are ones that you have to Start at the top. That seems like a lot of work just to replace that board.........? Thanks, Bob
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Unfortunately, it's not possible.
Apple goes back and forth with machines on making the upper case or the lower case the "base" of the machine. WIth the Pismo, everything is screwed into the lower case. It is impossible to remove all these connections from the bottom, as all the screws are accessed from the top.
Sorry!
War diese Antwort hilfreich?
Bewertung 1
From the top's the only way to go I'm afraid! It shouldn't be too hard, just follow the guide. (Watch out for step 41!)
Bewertung 0
Thanks to all that posted here re: getting to the Logic board from the rear, rather than from the top. I have the take apart manual, but will have a techie do it for me. Thanks again, Bob
Bewertung 0
Antwort hinzufügen
bobpal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 2,129
