Zum Hauptinhalt wechseln
Cen-Tech Seven Function Digital Multimeter . Model number 90899.
9 Fragen Alle anzeigen
Why won't the screen show any readout?
I want to use my multimeter to test a battery. The banana plugs are attached and cords are attached to the device, but the screen is not reading anything. My device is turned on and seems to be functioning otherwise.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
The reading screen is either broken or malfunctioning. You may need to replace the screen. See screen replacement guide here. If this does not seem to fix the problem, you may have an issue with the motherboard. Click here to see how to replace the motherboard.
Cen-Tech Seven Function Digital Multimeter Mainboard Bild
Anleitung
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Schwierigkeitsgrad:
Leicht
5 - 15 minutes
Cen-Tech Seven Function Digital Multimeter Screen Bild
Anleitung
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Schwierigkeitsgrad:
Leicht
10 - 15 minutes
War diese Antwort hilfreich?
Bewertung 0
I'm all for fixing stuff and keeping it working, but Harbor Freight literally gives these meters away. They're not worth fixing. i have a stack of spare ones still in the package waiting to be used.
Bewertung 0
Antwort hinzufügen
Anna Kihm wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 1,708
