Zum Hauptinhalt wechseln
An aviation themed analog luxury watch from Breitling.
2 Fragen Alle anzeigen
removing the bezel safely
How you you remove the bezel of a Breitling Navitimer Safely?
I heard there are screws holding the bezel down. hoo do i find these screws?
the gap between the bezel and case can barely fit a piece of paper. i can't get a knife in there. i plan to use a razor blade and see what happens.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Again I repeat don't try to use any blade as it could be held be three screws inside if its a later Navitimer.
Whereas the earlier 806 model can be lifted from outside with a proper Watchmakers blade.
Kind Regards,
Tony
Tony Arnold {Director}
arny@helios-electronics.com
War diese Antwort hilfreich?
Bewertung 1
It depends on the model number etc
kind Regards
Tony
Bewertung 0
Don't use a razor blade, the edge could break and send shards into sensitive tissues, like your eyes. Yikes!
A watchmaker's tool or iFixit's Jimmy tool would be better.
Jimmy Bild
Produkt
Jimmy
$7.99
Bewertung 0
Antwort hinzufügen
han wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 5
Letzten 7 Tage: 16
Letzten 30 Tage: 51
Insgesamt: 1,934
