temperature warning but cold to the touch
I was working on an iPad mini that was bent worse than an iPhone6+. The apex of the bend was located directly underneath the motherboard and the body was bent up toward the motherboard. I opened it up took, off the screen LCD, heat shield, and then bent the frame back applying no pressure to the motherboard (obviously). It came out really nice and straight and appeared to be a fully successful repair. A matter or minutes, if not seconds, after i turned it on to test it out the temperature warning came up and will not go away even though the iPad is not at all hot.
Ist dies eine gute Frage?
