Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1158 Fragen Alle anzeigen
Frage geschlossen
Replacement battery with iOS4 still working?
I heart that after an upgrade to iOS4 on an iPhone with a non original battery installed, charging the iPhone wasn't possible anymore.
Has anybody already experience with that?
Thanks, Christian
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I just replaced the ifixit battery with an original OEM battery (eBay - $8.25) and my phone restored perfectly (iOS4)! Im writing this reply with my now working iPhone 3GS.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
"original OEM" - well, it's only a nice phrase.
those cells can be good or bad - in your case - it was good, but the next one from the batch could have been bad. lipo cells are not easy to handle and depending on a few things like age, charging level when shipped, stored in a cold, dark room and so on - they can be good or bad.
in fact - using a lipo cell in a mobile device isn't the best thing i can think of (surely - the are pretty powerful, but even high grade produced ones can "explode" or have other issues - if they were slightly bent during the installtion - they could fail.
von
My experience hasn't been exactly this, but i have had issues being stuck in a restore loop (error 29) after i swapped out an old battery for a new ifixit battery AND THEN tried to update to iOS4. (It worked fine while i was still using iPhone OS 3.)
Once i attempted the iOS4 update, my phone went into a restore loop never to come out. See my original post for more details:
Why do I receive error code 29 when I attempt a restore?
At this point, i'm going to (try to) purchase an original OEM battery and see if that will unbrick my phone.
Bewertung 0
1 Kommentar:
Thank you for your info. In this case I will probably wait with the update.
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 2,274
