Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar:
liarliar, just like your other question:"Where did you measure for continuity? Why did you check for continuity? You should not have continuity between the battery tips. The more information you can give, the greater the likelihood to get a valid answer. "
von oldturkey03
