Home button/Power button failure?
I Bought a defective Iphone 5. I can see that the case has been replaced. The screen I received with it was broken and it. The seller showed it stuck on the apple sign.
I replaced the screen. The first go, it went straight to setup but I noticed the power button and home button were not responding. Also there were white lines on the screen and the touch did not work in the bottom right corner. I removed it and re-installed assuming that the cable was not correct correct. It then was stuck with the connect to itunes screen which I again bypassed. However the home and power button still did not work. I then took it apart again to ensure that everything was lined up include the mother board and sim. Some screws were missing so I replaced them with original Iphone 5 screws. However the home and power button both still do not work. Both flex cables appear fine to me and the bottons seem to function as normal. Does anyone have an idea as to what I should try next or if there is a part broken that I am missing?
Ist dies eine gute Frage?
2 Kommentare
Home button + Power button doens't work after display replacement? - I guess I found the answer here. I also found the replacement part for it as well.
von chuckvanbommel
Thank you so much. I came to the same conclusion! This should be the fix I was hoping for. Great.
von chuckvanbommel
