Zum Hauptinhalt wechseln
Apple hat das MacBook Pro 15" Unibody, die zweite Generation des MacBook Pro, im Oktober 2008 mit einem neuen Aluminium-Obergehäuse, das aus einem einzigen Aluminiumblock gefräst wurde, herausgebracht.
3092 Fragen Alle anzeigen
MacBook Pro 15" too slow after logic board replacement
Hello,
I have a macbook pro 15" mid 2009 and i've replaced my logic board. Before the upgrade i have a logic board with a core 2 duo 2.53 GHZ (4gb RAM and no dedicated graphic card). After the upgrade i have a logic board with a Core 2 Duo 2.66GHZ (4gb ram and a 9600M GT graphic card). I haven't replaced anything else. I have the same HDD with the same OS X install as i have before. But now my macbook pro is too slow some times. For example after opening a folder, the preview of the images is too slow. And crash many times.
I have to do a clean install to my macbook pro for everything works fine?
PS: I also see that my memory ram is almost close to the max value (4 GB).
MacBook Pro, OS X Yosemite (10.10.1)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try replacing the hard drive cable and possibly the hard drive. I use the newer cables from the 20012 because of the wider path. This cable gets damaged as it makes several 90 degree bends. When replacing I install pads so the bottom cover won't touch the cable.
See this question on the cable to use: Using new hard drive cable in older machines 821-1480-A
The machine will also take 8 GB of RAM.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
Hello,
Thank you for answer. So you think that i can have my data cable damaged? I will try to replace it. But one question. Why, before the replace, i don't see my macbook pro slow as it is at the moment :(
Are u thinking that hard drive is damaged too?
And i have to buy more ram too?
Regards
mistic
von
It's according to how fast you caught it. 50% of the time the hard drive is OK. Change the cable then run Disk Utilities from the recovery partition. No reason to upgrade the RAM.
von
Antwort hinzufügen
mistic wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,129
